Page 1 of 1
Supercharged and Turbocharged Jimny
Posted: Sat Jan 04, 2020 7:48 pm
by Keith Phillips
It all starts with buying a Swift Sport M16A VVT.
Compression ratio is a little high so it gets 9.0:1 Wiseco Pistons.
The con-rods are a little weak so it got K1 H beam rods installed.
A 0.5mm rebore brings the capacity to exactly 1600CC and leaves room for future reboring.
All the nuts and bolts on the cylinder head and crank were changed to ARP high strength ones.
A new trigger wheel was laser cut and installed for the Megasquirt MS3 to use the original crank sensor
and the cam had the trigger modified to leave a single trigger for sequential ignition and EFI.
Some pictures taken while figuring things out on the supercharger side.
Flange for the Turbo manifold.
The mount figured and fitted on the engine.
Programmed in Mastercam
Insulating spacer for the Jenvey inlet manifold.
Newer cam cover means COPs and no coil cover.
Made one and painted it wrinkle finish black.
Onto the Turbo Side.
Making a start on the manifold.
Probably going to plumb the external wastegate into the exhaust.....for peace!
Re: Supercharged and Turbocharged Jimny
Posted: Sat Jan 04, 2020 8:09 pm
by Jack
My god that looks beautiful :P
Are we guessing hp matey i say 240
Posted: Wed Jan 08, 2020 12:43 pm
by Tom
Incredible, can't wait to see this progress.
Posted: Sun Jan 12, 2020 10:42 am
by Keith Phillips
Bit of bling and the top is just about finished.
Posted: Thu Jan 16, 2020 10:16 pm
by The Cameraman
Wow,
what beautiful work.
Posted: Sun Feb 16, 2020 8:22 pm
by Keith Phillips
Supercharger belt drive started.
Posted: Fri Dec 23, 2022 10:48 pm
by Ruamann
Just amazing, like. Giz it haha.
